It is currently Mon Jun 08, 2026 11:21 pm
 Post subject: windshield wiper motor
PostPosted: Mon Apr 11, 2005 6:59 am
wont work....im hoping their might be a fuse out, but cant find the fuse for it. Read in manual that there is a breaker of some kind under the hood, but havent found it. Any hints on where to look??
Don't ever take a fence down until you know why it was put up.
-Robert Frost (1874-1963)
 Post subject: Ground
PostPosted: Mon Apr 11, 2005 7:33 am
Both of my old mopars wiper motors appeared to be properly grounded, but didn't work.
Try jumpering the body of the motor to a good ground.
It has worked for me every time so far. :)
1980 Aspen 225 super six
 Post subject: wiper
PostPosted: Mon Apr 11, 2005 10:47 am
Inside or attached to the wiper switch at the dash is a thermal breaker designed to open up if the motor tries to draw too much current - for example, if the arms were stuck in ice. The breaker resets when it cools down in 15-30 seconds or so.
The factory treats the wiper switch/breaker as a single unit, but another breaker could be substituted if you can't find a good switch.
Breakers aren't really intended to cycle a lot and tend to get flaky when that happens.
Switches, wiring, and motors are totally different for the 1sp, 2sp, and var/3sp setups.
Diconnect the leads at the motor and see if you get power there and make sure it's not just mechanically bound up.
