It is currently Sun Jun 14, 2026 3:53 am
PostPosted: Thu Apr 14, 2005 3:12 pm
When I got my slant the distrib was one tooth off and the best timing you could get was about 14-20 degrees BTDC. This caused ignition knock and when I finally got round to setting the thing right (About 6 degrees BTDC on my '76?), I noticed another problem has seemed to be resolved.
It used to be that on cold startup the engine would make a brief but loud and disturbing "knocka-knocka-knock" sound that would go away almost immediately. I assumed from all I have been told that I just had tired bearings (which I still probably do), but I haven't heard that sound since the timing was rolled back. Is it possible that the wrong timing was the cause of my startup knock?
PostPosted: Thu Apr 14, 2005 3:29 pm
...oil pressure coming up slowly PLUS all that initial timing banged on the rod and main bearings with the high cylinder pressure.
D/W
If it ain't broke, fix it!
