It is currently Sat Jun 20, 2026 8:24 pm
 Post subject: Help!!!!!!!!!
PostPosted: Thu Apr 14, 2005 7:45 pm
Water season is here and I discovered a minutes ago that my Duster don´t keep water in the outside, it let ALL the water enter in the front and fried almost everything up there!!!
Mopar Muscle is well defend by Slant Six!
Valiant Duster 1971
PostPosted: Thu Apr 14, 2005 10:09 pm
i had a leak from the wiper arm driped on the wires on down to the floor. got lucky it didnt get to the fuse box. i just got a little silicon around the base and it seems to hold out
PostPosted: Fri Apr 15, 2005 12:11 am
For new wiper pivot seals, take a look at Schumacher Creative Services at [url]engine-swaps.com[/url]. Also, make sure the drain holes for your cowl are clear and not plugged up with leaves and twigs.
Jerry
PostPosted: Fri Apr 15, 2005 5:47 am
Often the water appears to come from the wiper shafts but it does not.
It can be the windshield gasket. Years of rust and dirt under the window gasket and trim cause problems. If you were to actually remove the windshield and gasket you will see how it is made and there is an area on each end that tends to leak because of the way it is made. The rubber gasket just sits on top of metal with no real "sealing" area and this is often where it leaks. There are also a couple drain holes below the windshield under the trim strip. They are sometimes difficult to see because they are partially covered by the window gasket and if someone has squirted extra sealant in there they often mistakenly fill these drain holes (actually slots). Also dirt accumulates under the trim strip and plugs these drain holes.
I had a mysterious water leak on my Valiant that eluded me for years. It was the body seam behind the fenders, near the hood hinge area. There is about 3 or 4 layers of sheetmetal spotwelded there with some sealer applied over it at the factory. Mine had the bare seam exposed and water leaked in and ran down behind the kick panel and under the carpet. I had to remove splash shield and with my long arm I was able to smear some sealant over the seam with my finger. End of mysterious leak. This would be much easier to see and do if you actually remove the fenders.
 Post subject: Ok, Fixed leak (I think)
PostPosted: Fri Apr 15, 2005 8:21 pm
but now I can´t get my heater unit to work properly, never sends hot air, always cold air, someone knows the correct order of hoses from engine to heater unit?
Valiant Duster 1971
PostPosted: Fri Apr 15, 2005 10:19 pm
I'm assuming you're talking about the heater core - I don't think it matters which way you connect the hoses - assuming both the inlet and outlet are the same size, but you could always just swap them and see if things improve. If you have AC there is a heater control valve that could be bad, or it's linkage could be binding/jammed.
Steve G.
PostPosted: Sat Apr 16, 2005 9:35 am
Ok, I don´t have a A/C unit, only defroster, and already changed order of hoses but ist the same result.
Valiant Duster 1971
PostPosted: Sat Apr 23, 2005 8:48 am
Anyone got heater controls diagram?? I think a linkage is loose, the one that controls cold/hot air.
Valiant Duster 1971
PostPosted: Mon Jan 08, 2007 12:02 pm
The Drains On My Aspen Were Easy To Find / Clean. Small Rubber Flaps On The Firewall That Lead From The Cowl Which Is Covered By An Easy-To-Remove Plastic Grille While The Hood Is Up...
I Am Unsure However Where To Find These Drains On My Scamp...
Any Tips?
PostPosted: Mon Jan 08, 2007 12:20 pm
Any Tips?
They are incredibly easy to find with the fenders off. They are little openings on the side of the cowl. AFAIK there is no easy way to get to them.
PostPosted: Mon Jan 08, 2007 4:18 pm
AFAIK
PostPosted: Mon Jan 08, 2007 4:22 pm
"AFAIK" = As Far As I Know.
David Kight
'62 Valiant Signet, White
'98 Dodge Dakota
'06 Jeep Liberty
PostPosted: Mon Jan 08, 2007 4:25 pm
Oh...
PostPosted: Mon Jan 08, 2007 4:49 pm
Someone should put together a glossary of all the acronymns and post it somewhere. We take them for granted but for a new member they can be daunting.
David Kight
'98 Dodge Dakota
'06 Jeep Liberty
 Post subject: Acronym glossary
PostPosted: Mon Jan 08, 2007 5:10 pm
A glossary would take all the fun out of tryin' to figure em' out...
But I must admit, this one had me stumped too!
