It is currently Sun Nov 22, 2026 9:35 am
 Post subject: Kickdown band
PostPosted: Tue Apr 19, 2005 10:09 am
How i can adjust the kickdown band in torqueflite 904???
PostPosted: Tue Apr 19, 2005 12:34 pm
Loosen the jamnut(if that is what it is called???), and adjust the screw...
PostPosted: Tue Apr 19, 2005 2:20 pm
The KD adjuster is the one on the side of the trans above the shift linkage. Loosen the locknut, tighten the screw a good finger tight and back it out 1-1/2 turns. Tighten the locknut and you're done. :shock:
PostPosted: Tue Apr 19, 2005 4:22 pm
There is no such thing as a kickdown "band". Do you mean the kickdown linkage, or the intermediate or low/reverse band?
You asked a very similar question just yesterday, did it not give you the answers you wanted?
PostPosted: Tue Apr 19, 2005 6:51 pm
Hey, Step. The question yesterday, was about the kickdown linkage. While "kickdown" band may not be technicly correct, it is a common usage, for the intermediate, or 2nd gear band.
PostPosted: Wed Apr 20, 2005 8:43 am
Thanks !!!
PostPosted: Thu Apr 21, 2005 4:09 pm
So it is! I looked in my 77 Chrysler manual and there it was. Why do they call it the kickdown band?
