| Kickdown band https://slantsix.org/forum/viewtopic.php?t=12682 |
| Author: | SL6 CHILE [ Tue Apr 19, 2005 10:09 am ] |
| Post subject: | Kickdown band |
How i can adjust the kickdown band in torqueflite 904??? |
| Author: | Rust collector [ Tue Apr 19, 2005 12:34 pm ] |
Loosen the jamnut(if that is what it is called???), and adjust the screw... |
| Author: | slantzilla [ Tue Apr 19, 2005 2:20 pm ] |
The KD adjuster is the one on the side of the trans above the shift linkage. Loosen the locknut, tighten the screw a good finger tight and back it out 1-1/2 turns. Tighten the locknut and you're done. |
| Author: | steponmebbbboom [ Tue Apr 19, 2005 4:22 pm ] |
There is no such thing as a kickdown "band". Do you mean the kickdown linkage, or the intermediate or low/reverse band? You asked a very similar question just yesterday, did it not give you the answers you wanted? |
| Author: | Charrlie_S [ Tue Apr 19, 2005 6:51 pm ] |
Hey, Step. The question yesterday, was about the kickdown linkage. While "kickdown" band may not be technicly correct, it is a common usage, for the intermediate, or 2nd gear band. |
| Author: | Guest [ Wed Apr 20, 2005 8:43 am ] |
Thanks !!! |
| Author: | steponmebbbboom [ Thu Apr 21, 2005 4:09 pm ] |
So it is! I looked in my 77 Chrysler manual and there it was. Why do they call it the kickdown band? |
