It is currently Sun Nov 22, 2026 11:21 am
PostPosted: Tue Apr 19, 2005 4:07 pm
I was just given a "four speed" out of an 83 D-100 pickup. I really don't know that much about the history of it, but he gave me everything except the linkages and shifter. I'd like to put this into a 66 Dart that currently has a 904 in it.
First of all how do I identify what this transmission really is? My brother has it and I have yet to actually see it.
My next set of questions involve how do I go about making this swap, but without knowing what the tranny really is, I'll wait and search this message board first.
PostPosted: Thu Apr 21, 2005 4:28 pm
Hi there!
This should be an overdrive 4speed. 4speed trannies have 3 shift levers on the side. if two of em point upwards and one points downwards (or otherwise, dont remember) it´s an overdrive unit. if all three point the same direction, its a close-ratio-gears unit with 1:1 fourth gear.
installing this to an automatic car involves swapping a clutch assembly into the car, welding a shifter hump to the floor and fitting with the shifter linkage. a833 4sp is longer also (i think) so you might have to shorten the driveshaft. not a weekend job...
chris
PostPosted: Thu Apr 21, 2005 4:37 pm
http://www.slantsix.org/articles/4-spee ... speed1.htm
chris
PostPosted: Mon Apr 25, 2005 1:00 pm
Thank you
I found that article at the end of my unch Thursday and didn't get a chance to read it until today. It definately looks like I have an A-833. Now to get it home, and find out how much work I have ahead of me.
I'm not expecting it to be a weekend job. This is my project car, that I am hoping to get started on some time soon.
