It is currently Tue Nov 17, 2026 6:45 pm
 Post subject: 2bb on a 1bb manifold
PostPosted: Sat Apr 23, 2005 12:18 pm
hi, my holley1920 is starting to go out on me, so i was wondering if i could just put a 2bb onto the original 1bb intake manifold. what parts do i have to get besides an adapter plate? thanks for any help you guys can give me. also, if anyone has a float for the holley 1920, i would gladly buy it off you.
casey
PostPosted: Sat Apr 23, 2005 3:28 pm
ain't make sense to put a 2 bbl carb over a 1 bbl mani. The right manifold wouldn't be so expensive and wouldn't be a pain in the ass to install, so find yourself a supersix conversion kit from any junkyard. Make sure you get all the linkages, tranny, throttle cable, gas pedal (if you have the earlier rod type) if you find a good deal you may be able to get the whole thing including carb (wich most likely would have to be overhauled) under 100 bux.
Juan Ignacio Caino
PostPosted: Sat Apr 23, 2005 3:46 pm
Argentina-Slantsixer is right. Use the correct 2bbl intake manifold if you want a 2bbl carb. The adaptor plates are silly and create problems.
Floats for Holley 1920s can still be had from NAPA Echlin and Standard-Hygrade. Probably from Holley, too!
