It is currently Wed Nov 18, 2026 2:56 am
 Post subject: distributor question
PostPosted: Sat Apr 23, 2005 2:33 pm
jack kumer
 Post subject: part#
PostPosted: Sat Apr 23, 2005 2:37 pm
forgot to list part# for the Chrysler 360 HP distributor it is 3874097
jack kumer
PostPosted: Sat Apr 23, 2005 3:24 pm
slant and big/small block dists ain't swap.
if you wanna get best mpg you have to stick with high initial timing. Maybe your vac pod is too large for a manual tranny (especially being OD) try to use a smaller ratio vac pod.
Juan Ignacio Caino
PostPosted: Sat Apr 23, 2005 3:39 pm
Standard/Bluestreak vacuum advance for the '76 Dart Lite/Feather Duster economy models with \6 and 4spd is VC208. Has a really LONNNNNNNNG throw, which is what you're asking for.
PostPosted: Sat Apr 23, 2005 10:26 pm
so I got it backwards? :oops:
Juan Ignacio Caino
PostPosted: Sat Apr 23, 2005 11:04 pm
No, you didn't get it wrong. The long-throw vacuum advance allows a large amount of advance under mileage-making part-throttle conditions despite a moderate (say 3° to 5° BTDC) initial timing setting, for easy starting and ping prevention under acceleration.
 Post subject: dfistributor
PostPosted: Sun Apr 24, 2005 3:54 pm
thanks I'll look into the bluestreak vc208
jack kumer
