| distributor question https://slantsix.org/forum/viewtopic.php?t=12730 |
| Author: | jack kumer [ Sat Apr 23, 2005 2:33 pm ] |
| Post subject: | distributor question |
| Author: | jack kumer [ Sat Apr 23, 2005 2:37 pm ] |
| Post subject: | part# |
forgot to list part# for the Chrysler 360 HP distributor it is 3874097 |
| Author: | argentina-slantsixer [ Sat Apr 23, 2005 3:24 pm ] |
slant and big/small block dists ain't swap. if you wanna get best mpg you have to stick with high initial timing. Maybe your vac pod is too large for a manual tranny (especially being OD) try to use a smaller ratio vac pod. |
| Author: | SlantSixDan [ Sat Apr 23, 2005 3:39 pm ] |
Standard/Bluestreak vacuum advance for the '76 Dart Lite/Feather Duster economy models with \6 and 4spd is VC208. Has a really LONNNNNNNNG throw, which is what you're asking for. |
| Author: | argentina-slantsixer [ Sat Apr 23, 2005 10:26 pm ] |
Quote: Standard/Bluestreak vacuum advance for the '76 Dart Lite/Feather Duster economy models with \6 and 4spd is VC208. Has a really LONNNNNNNNG throw, which is what you're asking for.
so I got it backwards? |
| Author: | SlantSixDan [ Sat Apr 23, 2005 11:04 pm ] |
No, you didn't get it wrong. The long-throw vacuum advance allows a large amount of advance under mileage-making part-throttle conditions despite a moderate (say 3° to 5° BTDC) initial timing setting, for easy starting and ping prevention under acceleration. |
| Author: | jack kumer [ Sun Apr 24, 2005 3:54 pm ] |
| Post subject: | dfistributor |
thanks I'll look into the bluestreak vc208 |
