It is currently Fri Nov 20, 2026 9:42 am
PostPosted: Thu Apr 28, 2005 2:16 pm
What issues do I need to look out for?
This engine runs great and tranny also.
I am going to rebuild both and am looking for a daily driver with some pep.
I will probably go Dutra Duals, port and polish the head and little else.
Will the 64 K member accept the 77?
Can I use the tranny mount from the Aspen?
DO I need a totally new hump?
Z bar issues?
I also have a 8 & 1/4 rear out of a 74 Duster that I got the parts from for the disc brake swap.
Thanks in advance
 Post subject: Pan
PostPosted: Thu Apr 28, 2005 2:23 pm
You need 66 or earlier pan to work with the 64 K member.
John
PostPosted: Sun May 01, 2005 10:32 am
The F-body oil pn can be used if you dimple the left front corner of the sump and use a V8 center link. If that is not available, then you can dimple the pan where it rests on the center link.
Users browsing this forum: Bing [Bot] and 9 guests
