engine mods
https://slantsix.org/forum/viewtopic.php?t=12750
Author:  vitamindart [ Sun Apr 24, 2005 3:46 pm ]
Post subject:  engine mods
i am wondering if anyone has tried turning down the counter weights on a
forged crank and if so where there any balancing problems???
also are there any aftermarket balancers availible????can a small or big block balancer be modified to work????
has anyone ever used olds valves it looks like with a lash cap they will be the correct lenght and i can turn the head size down to what i need.
any help would be greatly apreciated
thanks vitamindart
Author:  Charrlie_S [ Sun Apr 24, 2005 5:45 pm ]
Some people have lightend slant cranks. Doug had some pictures posted someware, but I couldn't find them. Fisher has a balencer for the slant. Also a big block balencer can be used with some minor modifications, but the pulleys do not line up. Have no idea on the valves.
Author:  slantzilla [ Sun Apr 24, 2005 7:50 pm ]
I overheard Doug explaing about the crank lighteneing out in Vegas. IIRC, when the bob weights are cut, Mallory metal has to be added making the entire process a wash.
As far as valves go, Ferrea is making a drop-in Slant valve now that is relatively low cost. (or so I've been told) :shock:
Author:  Tom Drake [ Mon Apr 25, 2005 4:53 am ]
Answer this question - Why did the factory put the large counter weights on the crank to begin with?
Author:  Dave M [ Mon Apr 25, 2005 4:36 pm ]
I removed 10 pounds from a stock weight crankshaft. THAN I took it to the machine shop and they rebalanced the shaft. This was after the poor guy spend serveral ??? hours TRYING to rebalance it. When I picked up the crank he asked me if this was a running engine because he had never seen a crank so far out of balance.....so I just played dumb and said I didn't have any history of that crank. Well it has been in my car for 2 years now with no problems. It was worth it BUT it was also lots of work and money. As far as damper I just use a big block and change the front seal.
Dave M
Author:  Dart270 [ Mon Apr 25, 2005 6:54 pm ]
Also, the later cast crank motors have much lighter cranks, apparently. The 80s ones supposedly only weigh about 55-60 lbs. I believe this is what Rodney has had in the Lancer for the last 3-5 yrs of drags w/ no issues.
