It is currently Mon Nov 30, 2026 12:51 pm
 Post subject: spool k- member
PostPosted: Thu Apr 28, 2005 6:47 pm
when swapping the spool k-frame into an earlier style car 67-?? anything special to look for or is the mounts the only difference , thanks
PostPosted: Tue May 03, 2005 7:05 pm
pretty much just the mounts are different as well as the idler arm. the 68 and up frames had the thru-bolt idler where the 67 and down had the stud mount. also the '73 and up k frames had the swaybar routed thru the center of the frame ane the lcas had the mounts moved inboard for these bars.
-james
