It is currently Sun May 03, 2026 7:12 pm
PostPosted: Wed May 04, 2005 3:38 am
I need to drop the tie rod assembly and possibly the center link so I can squeeze the header in...I want to continue using the tie rod till I get a chance to replace the whole front suspension with new parts later. Would I use a tie rod puller rather than the pickle fork way? This is on a 1970 duster with slant 6 and manual 3 speed and no power brakes and steering.the header is a MP 6 into 1...thanks...Jerry
73 Dart 4dr
70 duster
75 VW bug
ex-88 honda rice rocket
ex-70 cuda 383
PostPosted: Wed May 04, 2005 6:54 am
Just asking, but why do you need to separate the steering? My MP header went into my Duster from the top. :shock:
PostPosted: Wed May 04, 2005 10:03 am
I believe a pickle fork is only used to DESTROY things. The
tie rod puller, carefully used leaves the tie rod end and usually
even the boot usable.
I remember on my 68 dart 170 with clifford 6:1 headers I had to
run the steering linkage between the tubes - sure made it a pain
to work with that setup. Also bottomed out on the smallest bumps.
Good luck.
PostPosted: Thu May 05, 2005 3:22 am
Thanks relic-lover, i thought the tie rod remover was the way to do it.
slantzilla..i tried to put the headers in last year, and just kept bumping in things.. the header assembly is pretty bulky and long.it looks like the tie rod center link is in the way. I didn't try it without the starter, as it looks like it wasn't in the way. How did you manage to squeeze it in...did you do it from the bottom? come to think of it, I didn't try it with turning the wheels, maybe it will clear that way, as it may move the tie rod-center link enough out of the way..
I am willing to tried any suggestions....thanks guys ...Jerry
73 Dart 4dr
70 duster
75 VW bug
ex-70 cuda 383
PostPosted: Thu May 05, 2005 5:09 am
I just laid it in from the top. With the manifolds and exhaust out there is gobs of room. Trans cooler lines do have to be rerouted though. :shock:
 Post subject: tie rod
PostPosted: Fri May 06, 2005 2:54 am
okay..I will try it again, maybe it will wiggle in this time..thanks....
73 Dart 4dr
70 duster
75 VW bug
ex-70 cuda 383
