It is currently Sat Nov 21, 2026 5:05 am
 Post subject: Ignition Conversion
PostPosted: Wed May 04, 2005 11:41 pm
i have a question, well yeah!
okay so check it out.. if i have the pertronix flame thrower 2 coil, which has an internal resistor, and i switch over to the orange box with the electronic distributor, do i have to run a ballast resistor?
i'm sorry guys, i've been cracking my head trying to figure out a setup....
thanks
70 Plymouth Valiant 4dr
 Post subject: No, Maybe
PostPosted: Thu May 05, 2005 6:02 am
That's part of the answer. The other part is how much?
Too little resistance will cause the orange box to overheat and burn out more quickly. I don't really know how close you need to be for things to be O.K., but I did run a standard ECU/coil without a balast resistor for about a year until the coil died, ECU is still going strong, but balast and new coil (stock) is now in place for several months.
I think you will be fine without, but I'm hardly an electrical expert.
1980 Aspen 225 super six
 Post subject: Taling About Ignition
PostPosted: Thu May 05, 2005 8:32 pm
Hey guys! wich type/brand of electronic ignition can you suggest me?
Mopar Muscle is well defend by Slant Six!
Valiant Duster 1971
PostPosted: Thu May 05, 2005 11:54 pm
Car Model: Valiant V200 225 4dr three on the tree
MSD 6 A
(cause I bought one)
Lasse
Signet -66 225
Holley 600 Offy-5270 Dutra Dual,regrind. cam 272 0,420 110, head shaved 0.100 slight.ported
MSD6A
A904
7 1/4 3.23
PostPosted: Fri May 06, 2005 4:27 am
MSD 6 A
OK I'll second that since I got a 6AL too, and then we'll cover for each other when the GM HEI squad attacks leading by.... SSD? :) :wink:
Juan Ignacio Caino
PostPosted: Fri May 06, 2005 5:55 am
You need the GM HEI setup, it is much better than anything else in the whole world! :wink:
It is a nice setup anyway.
As is the msd
Or XXXXXXXXXXX
Or ZZZZZZZZZZZ
Or _____________ :roll:
______________ is good for a stock daily driver.
XXXXXXXXXXX is better with a built engine and more rpm´s
I guess it is pretty much up to you...
I like the stock mopar electronic ignition.
Or HEI...
PostPosted: Fri May 06, 2005 2:31 pm
HEY, awright, nuttin wrong with the HEI. Just that if when you hit the bed you picture a part of your beloved mopar that came from the insides of a shivvy.... well, I prefer dreamin' of freddy krueger. C'mon, it's like alien: yoou *know* is gonna change your behavior and eat your guts to find his way out your turned-into-host body. ¡Yikes! no goodnight sleep for me tonight if I were on HEI.
There's HEI quitting clinics that give you MSDONE instead... :roll:
Juan Ignacio Caino
PostPosted: Fri May 06, 2005 2:38 pm
Just use a hei module from a non chevy then...
I have a module that was made by bosch...From an Opel.
Maybe the car will rust faster, but then again, I think Freddy is a nice guy too :twisted:
PostPosted: Sat May 07, 2005 5:49 am
By the way, the HEI quitting clinic is sponsored by Betty Ford and the Dodgers, among many other non gov organisations.
Juan Ignacio Caino
