| Ignition Conversion https://slantsix.org/forum/viewtopic.php?t=12869 |
| Author: | ValiantBoyWonder [ Wed May 04, 2005 11:41 pm ] |
| Post subject: | Ignition Conversion |
i have a question, well yeah! okay so check it out.. if i have the pertronix flame thrower 2 coil, which has an internal resistor, and i switch over to the orange box with the electronic distributor, do i have to run a ballast resistor? i'm sorry guys, i've been cracking my head trying to figure out a setup.... thanks |
| Author: | Slant6Ram [ Thu May 05, 2005 6:02 am ] |
| Post subject: | No, Maybe |
Quote: which has an internal resistor
That's part of the answer. The other part is how much?Too little resistance will cause the orange box to overheat and burn out more quickly. I don't really know how close you need to be for things to be O.K., but I did run a standard ECU/coil without a balast resistor for about a year until the coil died, ECU is still going strong, but balast and new coil (stock) is now in place for several months. I think you will be fine without, but I'm hardly an electrical expert. |
| Author: | Avenger2040 [ Thu May 05, 2005 8:32 pm ] |
| Post subject: | Taling About Ignition |
Hey guys! wich type/brand of electronic ignition can you suggest me? |
| Author: | skraecken [ Thu May 05, 2005 11:54 pm ] |
MSD 6 A (cause I bought one) |
| Author: | argentina-slantsixer [ Fri May 06, 2005 4:27 am ] |
Quote: MSD 6 A (cause I bought one) |
| Author: | Rust collector [ Fri May 06, 2005 5:55 am ] |
You need the GM HEI setup, it is much better than anything else in the whole world! It is a nice setup anyway. As is the msd Or XXXXXXXXXXX Or ZZZZZZZZZZZ Or _____________ ______________ is good for a stock daily driver. XXXXXXXXXXX is better with a built engine and more rpm´s I guess it is pretty much up to you... I like the stock mopar electronic ignition. Or HEI... |
| Author: | argentina-slantsixer [ Fri May 06, 2005 2:31 pm ] |
HEY, awright, nuttin wrong with the HEI. Just that if when you hit the bed you picture a part of your beloved mopar that came from the insides of a shivvy.... well, I prefer dreamin' of freddy krueger. C'mon, it's like alien: yoou *know* is gonna change your behavior and eat your guts to find his way out your turned-into-host body. ¡Yikes! no goodnight sleep for me tonight if I were on HEI. There's HEI quitting clinics that give you MSDONE instead... |
| Author: | Rust collector [ Fri May 06, 2005 2:38 pm ] |
Just use a hei module from a non chevy then... I have a module that was made by bosch...From an Opel. Maybe the car will rust faster, but then again, I think Freddy is a nice guy too |
| Author: | argentina-slantsixer [ Sat May 07, 2005 5:49 am ] |
By the way, the HEI quitting clinic is sponsored by Betty Ford and the Dodgers, among many other non gov organisations. |
