It is currently Sat Nov 21, 2026 2:01 am
PostPosted: Thu May 05, 2005 10:07 am
Car Model: 71 Dodge D100 64 Plymouth Valiant Wagon
Sometimes I just don't get it, but I'm hoping somebody can explain. :oops:
I've got a 71 D100 with a 727 transmission. Because I can get a really good deal and I've had a lot of problems with BBD throttle shafts, I'm thinking about picking up an Edelbrock 500cfm 4bbl.
Lokar has a kickdown cable for 727 transmissions. On my transmission, the kickdown is activated by a kickdown rod.
So, how does a cable take the place of a rod? Is there some extra lever to install or something?
Thanks for your learned responses,
Joe
Joe Hoppe
71 D100 225 Super Six 727 AT on 2008 Crown Vic CopCar frame
64 Valiant Wagon 225 904 AT 3:23 8.75"
PostPosted: Thu May 05, 2005 12:21 pm
The cable takes the place of the rod, and has a bracket that mounts at the tailshaft extension. On the kits that I have, I had to make a small bracket for the carb end, but it wasn't complicated and worked very well when done. :shock:
PostPosted: Thu May 05, 2005 4:17 pm
hey.
I did a custom bracket on the carb lever too.
later I drilled 2 holes above the one you see, so I can get 3 kickdown feels, a short throw one for firmer shifts and moer sensitive kickdown, a middle position and a "town" mild shifting that feels like the stock rod.
Juan Ignacio Caino
PostPosted: Fri May 06, 2005 6:12 am
Thanks, 'zilla and Slantsixer.
How does the bracket hook up to the transmission? Do you have the kit number? All I could see was the cable itself.
Thanks again for your expertise,
Joe
Joe Hoppe
PostPosted: Fri May 06, 2005 1:32 pm
I have the 904 kit in my car... I thought the 727 and 904 are same cables?
On my 904 kit, the transmission bracket is built into the cable itself, its just a small tab of metal that the cable already goes through, and you bolt into one of the tailhousing bolts. The cable comes from the carb to the tailshaft bolt, pulls a 180, then attaches to the kickdown.
PostPosted: Fri May 06, 2005 2:26 pm
727 and 904 are indeed the same cable. code is H....xxx...2727 or something like that :wink:
Juan Ignacio Caino
