It is currently Mon Nov 23, 2026 12:23 am
 Post subject: cable tranny questions
PostPosted: Sat May 07, 2005 10:21 am
I have some spare cables for the push button style , does anyone kow lengths ? I think I have a set for the 65 floor shift style & then 1 for the park brake which will fit my 62. 1 more ? will the small block 727 cables work on the the slant six 904's. Thanks
PostPosted: Sat May 07, 2005 3:33 pm
Cable length is determined by body type (A-body, B-body) and shifter type (pushbutton, column lever, floor lever). 727 and 904 cables are the same.
 Post subject: cables
PostPosted: Mon May 09, 2005 4:51 am
Thanks Dan, I don't think I have any pics of the 235's under the rear of the 62- but they sure looked good. Yes I'm also running 205/70/14's but they rub occasionally on severe turns. I have not replaced any suspension pieces yet, but I figure that the extra flex is causing the rub- I noticed how high your front was on your Lancer -I'm assuming it's to clearance the tires?? Later
