It is currently Sat Nov 21, 2026 7:46 pm
PostPosted: Wed May 11, 2005 1:12 pm
so my turn signals decided to stop working, i don't know when this exactly happened.
so i checked the switch, by pushing the brake and turning the signal, the light goes off in the back of the car (thanks dan!)
i changed both flasher boxes and checked all fuses, everythings okay
but down by the ash tray, the fuse for the turn signals keeps blowing out, when i turn the key to acc. the flaser goes off even without the switch in the left or right position. it keeps clicking until the fuse finally blows, and when i take the fuse out, boy is it hott!!!
70 Plymouth Valiant 4dr
PostPosted: Wed May 11, 2005 6:50 pm
you have a short some where in your turn signal wiring. follow the wires going from the flashers to the switch and to the bulbs. there is a bare wire or pinched wire in that circut.
