It is currently Sat Jun 13, 2026 2:43 pm
PostPosted: Sat May 21, 2005 7:56 pm
I am looking at a Unilite distributor that just recieved from slant6dan.
On the stem there is a cam shaped piece held with 2 allen head set screws. Is this used with original distributor hold down clamp? Or is there something else I need to fit this in?
I don't want to pull my old dist without having everything ready to put the Unilite in.
There is no problem that cannot be solved by the proper application of thermo nuclear weapons
PostPosted: Sat May 21, 2005 10:22 pm
Does your stock distributor have a sheetmetal hold-down bracket with a slotted hole for the bolt that holds it into the block? If so, transfer that to the UniLite. If not, you need such a plate (some of the later \6s have a V8-like arrangement with the block hold-down bolt holding a V-claw-shaped hold down bracket, which bears against a ring on the distributor body).
PostPosted: Sun May 22, 2005 4:24 pm
I have the v / claw type hold down with a bolt that clamps onto a ring on the dist. I haven't seen the other hold down set up. If I had a photo I'd understand it better, and, if I had to, make one up. Can any one shoot a photo of this set up and email it to me?
I'm at jwl540@hotmail.com
PostPosted: Sun May 22, 2005 7:10 pm
I haven't tried it, but I bet that ring bolted onto your stock distributor will also bolt to the cam-shaped piece on the Mallory, then you can use your stock hold down claw.
Users browsing this forum: Ahrefs [Bot], Amazon [Bot] and 2 guests
