It is currently Sat Nov 21, 2026 8:53 pm
PostPosted: Tue May 31, 2005 8:42 pm
Does anyone know of a chart I can use to find the correct speedometer gear for my A833? 27 inch tire, 3.23 gear ratio, overdrive transmission. Thanks, Tom
PostPosted: Tue May 31, 2005 9:22 pm
You need a 32-tooth pinion 2538932. See Here
PostPosted: Wed Jun 01, 2005 5:34 am
Those speedometer pinions are still available from your local dealer. However the part numbers have changed and the last two digits of the part number no longer indicate the number of teeth.
I don't know why they had to change the parts numbers to non-sense.
PostPosted: Wed Jun 01, 2005 8:20 am
PreZISSHHun Churrrman partsgenummerssystemsreich von DaimlerChrysler.
PostPosted: Thu Jun 16, 2005 5:51 pm
I looked at the chart and got the gear I needed. I thought I would be changing the gear that goes into the transmission, but it is not the same, so I guess I need to change the gear that goes into the speedometer. How do I do this?
Also, the gear that goes into the transmission broke, so I need to replace it. What is it called? Where can I get it?
Thanks.
PostPosted: Tue Jun 21, 2005 6:01 am
Two places have now given me the wrong gear. I need the short plastic gear held on by a C clip. Does anyone know where to get these? They are for '65 and older vehicles.
PostPosted: Tue Jun 21, 2005 6:32 am
Ohhhhhhhhhh, you're working with an up-to-'65 transmission. Whoops, yeah, those are different and can't use the '66-up gears. The '65-down gears are much harder to find; you pretty much have to find them used. Ask Doctor Dodge.
Users browsing this forum: DuckDuckGo [Bot] and 3 guests
