It is currently Fri Jun 12, 2026 1:04 pm
 Post subject: Carburettor Problem?
PostPosted: Tue Jun 21, 2005 8:43 pm
When I start the engine I have fuel leaking from where the fuel line enters the 'carby (around the needle and seat area). I have tightened the fuel line connection, checked the needle and seat condition, however it still leaks fuel everywhere.
Any help to fix this problem is welcomed.
Thanks, Peter.
PostPosted: Tue Jun 21, 2005 8:47 pm
Inspect the end of your fuel line carefully; the flare may have cracked. Also check for stripped threads where the brass inlet fitting screws into the carb, and check that the proper gasket is used.
Users browsing this forum: Ahrefs [Bot], Google [Bot] and 6 guests
