It is currently Sun Sep 06, 2026 11:29 pm
PostPosted: Wed Jun 22, 2005 2:01 pm
I'm looking to add a K&N open element air filter to a '75 Dart that still has the original 1 bbl carb. Looking at K&N website, it is unclear to me which one I need, especially as it relates to hood clearance. Anyone else who has made this swap already, can you tell me which one to purchase?
Also, if I decide to move to a "Super Six" in the future, will the same open element setup fit over a 2 bbl carb or will I be stuck buying another new setup?
Here is a link to relevant section of K&N website:
http://www.knfilters.com/Racing/custom.htm
I just finalized registration of my car as a Wisconsin classic, and passed my last emissions test EVER :D so in addition to the new air filter I will be "losing" a lot of that emissions garbage (cough cough cat converter cough)
Thanks!
1975 Dodge Dart Swinger, 2 door red w/black vinyl top, under 56k original miles
PostPosted: Wed Jun 22, 2005 2:43 pm
A 1 barrel carb uses an 8" element and a 2 barrel carb uses a 10" element.
You can look and see what size you need by checking out what an 87(I believe was the last year the slant was available in a truck) pick up needed. That is what I had to do when I got the K&N for my supersix.
PostPosted: Wed Jun 22, 2005 2:56 pm
You could get the 2-barrel setup, then add a throat adaptor so it works with the 1bbl carb. When you get to a 2bbl, just remove the adaptor......
PostPosted: Wed Jun 22, 2005 3:15 pm
..or just get a good ole' wal-mart filter.
D/W
If it ain't broke, fix it!
PostPosted: Thu Jun 23, 2005 1:03 pm
Or get a cheapie open element assembly from Advance Auto.
82 D150-225/727
02 Dakota-3.9/5 speed
Users browsing this forum: No registered users and 14 guests
