Open element air filter from K&N - which is the right on
https://slantsix.org/forum/viewtopic.php?t=13431
Author:  RacineDart75 [ Wed Jun 22, 2005 2:01 pm ]
Post subject:  Open element air filter from K&N - which is the right on
I'm looking to add a K&N open element air filter to a '75 Dart that still has the original 1 bbl carb. Looking at K&N website, it is unclear to me which one I need, especially as it relates to hood clearance. Anyone else who has made this swap already, can you tell me which one to purchase?
Also, if I decide to move to a "Super Six" in the future, will the same open element setup fit over a 2 bbl carb or will I be stuck buying another new setup?
Here is a link to relevant section of K&N website:
http://www.knfilters.com/Racing/custom.htm
I just finalized registration of my car as a Wisconsin classic, and passed my last emissions test EVER :D so in addition to the new air filter I will be "losing" a lot of that emissions garbage (cough cough cat converter cough)
Thanks!
1975 Dodge Dart Swinger, 2 door red w/black vinyl top, under 56k original miles
Author:  70valiant [ Wed Jun 22, 2005 2:43 pm ]
A 1 barrel carb uses an 8" element and a 2 barrel carb uses a 10" element.
You can look and see what size you need by checking out what an 87(I believe was the last year the slant was available in a truck) pick up needed. That is what I had to do when I got the K&N for my supersix.
Author:  emsvitil [ Wed Jun 22, 2005 2:56 pm ]
You could get the 2-barrel setup, then add a throat adaptor so it works with the 1bbl carb. When you get to a 2bbl, just remove the adaptor......
Author:  Dennis Weaver [ Wed Jun 22, 2005 3:15 pm ]
..or just get a good ole' wal-mart filter.
D/W
Author:  Jeb [ Thu Jun 23, 2005 1:03 pm ]
Or get a cheapie open element assembly from Advance Auto.
