| Dyno results on 67 dart https://slantsix.org/forum/viewtopic.php?t=13446 |
| Author: | Russell Cable [ Thu Jun 23, 2005 6:48 pm ] |
| Post subject: | Dyno results on 67 dart |
I put my dart on the dyno tonight!! With the exaust still on the car and no NOS, I got 150hp at the wheels and 200 foot# of torq!! The 225 /6 got 210 hp at the crank. |
| Author: | argentina-slantsixer [ Fri Jun 24, 2005 5:16 am ] |
great #'s for a nonjuiced, no efi nor turbo slant (the way I like it) what did you do to your mill? some more info, please. |
| Author: | GuyLR [ Fri Jun 24, 2005 8:29 am ] |
Shouldn't 150 at the wheels be more like 185-195 tops at the crank? Otherwise you're looking at almost 29% for driveline losses! Quit ridin' the brakes |
| Author: | argentina-slantsixer [ Fri Jun 24, 2005 8:59 am ] |
maybe he has an odd rearend ratio (that can foul the dyno @ rear wheels measurement) |
| Author: | Guest [ Fri Jun 24, 2005 5:41 pm ] |
argentina-slantsixer the mill is a 225 bored .060 with .030 cut of the block. .115 cut of the head ported and polisher with 1.78 intake 1.50 exhaust valves. The cam is .490 lift and the carb. is a holly 600cfm. I got a MSD6A and recurved dis. electric fan and 100 hp NOS The car got a 904 trans. and 3.55 rear gears. The guy the ran the dyno said the car got 152.5 hp @ 4600 rpm and 201.2 torq @ 3400 rpm. He also said the car would have higher # if I ran with open exaust. Also he told me the trans. was sliping. Could this be why the rear wheel hp. and the crank hp. is off a lot? Can somebody tell me how to get more out of this car with out useing my NOS or my 4.56 gears? |
| Author: | Russell Cable [ Fri Jun 24, 2005 5:48 pm ] |
When I try on the dyno again I will try the 4.56 gears open exaust and the NOS. with the trans. repered. just to see the differance. |
| Author: | Russell Cable [ Sun Aug 07, 2005 3:51 pm ] |
I ran at the track this weaking and ran 15.045. And on nitrus I ran 14.440 at 94 MPH.. Now the thing is can somebody tell me how to go faster. There is more in this car ,but I can't get it out.. |
