| Philco II antenna trimmer? https://slantsix.org/forum/viewtopic.php?t=13661 |
| Author: | steponmebbbboom [ Tue Jul 12, 2005 7:44 pm ] |
| Post subject: | Philco II antenna trimmer? |
Where is the trimmer on this AM radio and how can I adjust it? My AM reception has always been weak and I was thinking about that while I had it out to replace my wiper shaft seals. |
| Author: | Avenger2040 [ Tue Jul 12, 2005 8:52 pm ] |
Have you thinked about using a radio signal amplifier? Keenwood make very good ones |
| Author: | steponmebbbboom [ Wed Jul 13, 2005 8:36 pm ] |
I dont believe those work on AM, but Id rather get what I have working its best rather than cover up the problem with something that doesnt belong there. |
| Author: | Avenger2040 [ Wed Jul 13, 2005 8:49 pm ] |
They work with any signal received to your radio by antenna, I got one installed in my car, and never got weak signal when I decide to listen to radio. |
| Author: | steponmebbbboom [ Sat Jul 16, 2005 10:09 pm ] |
Anyone got a factory manual they can scan for info on the trimmer pot? Thanks for the booster suggestion, but Id really rather fix the problem properly. |
| Author: | Jeb [ Sun Jul 17, 2005 2:00 pm ] |
Don't know if this helps you any but on the ancient AM/FM radio in my 66 C-10 the antenna trimmer is located on the backside of the radio. I can lay on the floor board and tunr the trimmer with my fingernail. I don't know if you can get to it that easy in cramped A-body however. |
