It is currently Tue May 19, 2026 12:53 am
PostPosted: Tue Jul 12, 2005 7:44 pm
Where is the trimmer on this AM radio and how can I adjust it? My AM reception has always been weak and I was thinking about that while I had it out to replace my wiper shaft seals.
PostPosted: Tue Jul 12, 2005 8:52 pm
Have you thinked about using a radio signal amplifier? Keenwood make very good ones
Mopar Muscle is well defend by Slant Six!
Valiant Duster 1971
PostPosted: Wed Jul 13, 2005 8:36 pm
I dont believe those work on AM, but Id rather get what I have working its best rather than cover up the problem with something that doesnt belong there.
PostPosted: Wed Jul 13, 2005 8:49 pm
They work with any signal received to your radio by antenna, I got one installed in my car, and never got weak signal when I decide to listen to radio.
Valiant Duster 1971
PostPosted: Sat Jul 16, 2005 10:09 pm
Anyone got a factory manual they can scan for info on the trimmer pot? Thanks for the booster suggestion, but Id really rather fix the problem properly.
PostPosted: Sun Jul 17, 2005 2:00 pm
Don't know if this helps you any but on the ancient AM/FM radio in my 66 C-10 the antenna trimmer is located on the backside of the radio. I can lay on the floor board and tunr the trimmer with my fingernail. I don't know if you can get to it that easy in cramped A-body however.
82 D150-225/727
02 Dakota-3.9/5 speed
