It is currently Tue Sep 22, 2026 5:18 am
PostPosted: Sun Jul 17, 2005 7:14 am
I have:
225 out of my '65 AUTOMATIC - 727 - that is getting rebuilt and put together slowly.
What do I do if I want to put this motor in front of my A745 Manual tranny in my '69?
Thanks,
Dan
"I may be slow, but at least I'm not very fast!"
'69 A108 - 225, 727, 3.55, MSD6AL, a.k.a.-the brick
PostPosted: Sun Jul 17, 2005 7:38 am
Just make sure that the crankshaft's rear face is bored for a pilot bushing—many cranks originally used in front of automatics aren't—and install said bushing.
I am fairly sure there's a "problem solver" thinwall pilot bushing available for cranks that weren't finish-bored to accept the standard pilot bushing.
PostPosted: Sun Jul 17, 2005 10:30 am
Don't know if it will work for slants but for LA motors without the bushing you can use a 92 or thereabouts roller bearing that fits the unfinish crank
PostPosted: Sun Jul 17, 2005 10:41 am
When I tried installing a manual behind an automatic engine years ago, I found the bushing from the parts store would not fit the hole in the crank. I put the bushing on a mandrel and in a lathe and cut down the outside to fit the crank hole. Problem solved !!
PostPosted: Sun Jul 17, 2005 7:47 pm
So you are saying that the engine side is smaller and I need to add a bushing to it and bingo - it will work?
PostPosted: Tue Jul 19, 2005 6:17 am
I have:
Thanks,
Dan
In general, a 65 crank should have the small crank flange / hub, the 69 should be the larger. If you have a "small hub" flywheel then all will bolt together. (be sure to install a pilot bushing as noted above)
Users browsing this forum: Bing [Bot] and 20 guests
