It is currently Sat Nov 21, 2026 2:12 am
 Post subject: Wont shift to third...
PostPosted: Wed Jul 20, 2005 3:59 pm
Well, seems like the third gear on my 904 has gone for a long vacation... :( what has happened?
Signet '68 4dr, 460k miles and still rollin'
PostPosted: Fri Jul 22, 2005 3:47 am
do you have reverse?
check oil level with car idling in neutral (after warmup) stop, then shift 1 - 2 - D - N - R - P - then N again and check the level with engine on. (make sure your car is parked on a flat evenly leveled surface)
maybe presure? you can crank up the nut counterlocked shaft that comes out above shifter/kickdown linkage on the driver's side of your transmission. Spin it 2 full turns, adjust the locking nut and see what happens.
Juan Ignacio Caino
PostPosted: Fri Jul 29, 2005 1:42 pm
Will start with changing oilfilter, as far as I have known the gearbox have seen no attention since '94, after coming across one previous owner at a meeting the other weekend, service record, or the lack of it, is set back to 1989 :D
