It is currently Sat Jan 03, 2026 5:02 am
 Post subject: Fuel Pump
PostPosted: Thu Aug 04, 2005 6:33 pm
I just put on a fuel pump and I noticed the new one doesn't have a spring connected to the arm. Is the new one spring loaded in another way or am I missing the spring? Also I've started to notice a lobing sound from that area is that normal?
82 D150 Slant6 Shorty
http://www.cardomain.com/ride/658846
PostPosted: Thu Aug 04, 2005 7:58 pm
You do need the spring -- sounds like your new pump came through with a missing piece. That spring keeps the pump arm on the camshaft to eliminate the knocking noise that would otherwise result.
PostPosted: Thu Aug 04, 2005 8:41 pm
man. Im starting to think that problem is common. I bought a new fuel pump without a spring to!!!
 Post subject: fuel pump
PostPosted: Thu Aug 04, 2005 8:54 pm
I curious to find out what brand fuel pump that was.
I installed a airtex pump from carquest and so far it work okay.
i think the airtex has lifetime warranty from carquest.
PostPosted: Fri Aug 05, 2005 1:51 pm
It was a Master fuel pump from Auto Zone. Has a Limited lifetime warranty. $14.00
PostPosted: Fri Aug 05, 2005 2:06 pm
Can I use the spring from the bad pump? I kept it just in case.
PostPosted: Fri Aug 05, 2005 3:29 pm
Maybe the design if the pump was changed (improved) so it no longer needs the external spring? Maybe it has in internal spring instead?
PostPosted: Fri Aug 05, 2005 5:02 pm
They all have internal springs.
The external spring is supposed to be there to prevent the knocking noise as formerly described. I'm sure some clueless Lexus-driving MBAsshole decided that it could be eliminated for an 8-cent cost reduction in the manufacture of the part, since only poor people and losers drive old cars, anyway.
PostPosted: Fri Aug 05, 2005 5:27 pm
what a bunch of douches, they shud eat their $#!+.
Users browsing this forum: Ahrefs [Bot], Google [Bot] and 11 guests
