It is currently Fri Jan 02, 2026 5:55 pm
PostPosted: Wed Aug 10, 2005 9:32 am
Any of you ever heard of the Direct Hits ignition systems? It's pretty much just a set of non-resistor spark plugs with capacitors/shielding plugs over the tops of them, from what I can tell. I've talked to a few people who've tried it on their trucks and they claim it's the real deal. No "snake oil". I'm going to order a set for my truck and if they really are as good as people say they are, my girl wants to try it on her slant. Something like that (again, if it works as advertised) with the HEI conversion sounds like it could be a helluvan upgrade to the factory slant ignitions. Just wondering if any of you guys have heard of 'em.
PostPosted: Wed Aug 10, 2005 10:32 am
Sure, secondary capacitors. JC Whitney and Honest Charlie used to sell setups like this in the '60s and '70s, with the same hyped claims of mega mileage, faster pickup, and possibly better-tasting coffee. Same bogus "Wow, look how much bigger and brighter the spark is!" photographs, too. A spark plug either works (lights its cylinder) or doesn't. Color me skeptical, especially with the handwaving and pseudoscientific advertising hype we see for this system (e.g. Here).
What exactly do they claim? The usual jive, a bunch more MPG, two seconds off their ET, etc? People say the same thing about Slick-50, splitfire spark plugs, and all kinds of other crapola.
(And I see they supply Bosch spark plugs, which are now made in China. Yaaaay!)
PostPosted: Wed Aug 10, 2005 11:02 am
Well considering our trucks are Toyota Land Cruisers, anyone running one in a quarter mile would be a complete idiot to begin with :P
But the claims are basically a small but noticable power increase, and slight mileage improvement. Nothing along miracle product lines, but definately noticable. I attribute it to just the fact that they're non-resistor plugs. from the looks of it, they just took old technology and figured out how to make it work much more reliably.
PostPosted: Wed Aug 10, 2005 11:22 am
Not me. Nonresistor plugs do not give better performance or mileage than resistor plugs.
I attribute it to the new spark plugs they include with the kit, which will usually be used to replace old spark plugs. Nothin' more or less than that, just a new set of spark plugs.
I see no data suggesting this system is reliable or previous systems weren't.
PostPosted: Wed Aug 10, 2005 11:35 am
Yeah I've found nothing along those lines either. That's just going off of what I've been told by guys who've ordered the system. These dudes have been gearheads since before I was born, so they've seen alot more stuff like that than I have :P
I'll find out if it's just due to the new plugs or not though, since I always keep my plugs clean, perfectly gapped, and indexed (I check 'em every time I change my oil just in case something starts to show up. At 212K miles I figure it's a good idea).
PostPosted: Wed Aug 10, 2005 3:38 pm
Car Model: '23 T-bucket
If I'm not mistaken, non-resistor plugs equal static from your radio.
Roger
PostPosted: Wed Aug 10, 2005 7:25 pm
Let's Roll...
Way ahead of ya. :roll:
PostPosted: Thu Aug 11, 2005 5:08 am
One thing that I think's a little weird about their system. A lot of aftermarket systems (and, for that matter, some Ford EDIS and other stock systems found on newer cars) use either an extended burn or fire multiple sparks. It seems this is effective on some engine designs, but not on others. My guess is that when it works, there is enough motion in the combustion chamber that the flame front drifts away from the spark plug and the extended burn or extra sparks create a longer flame front.
But what's interesting about DirectHits is that it seems to take the opposite approach. They brag about a higher voltage, but it's for a much shorter time. I suppose this could work if an engine's cylinder pressure was so high the stock ignition couldn't reliably ignite it and caused it to missfire. But if the stock ignition works, this seems like a step backwards.
BTW, anybody have any dyno test results from running an MSD box or similar mult-spark system on a slant six?
"Mad Scientist" Matt Cramer
'66 Dart - turbocharged 225
PostPosted: Thu Aug 11, 2005 6:18 am
Notice the first part of the claim in the ad copy: "This is reported to ..." Those, my friends, are weasel words. If they could prove it, they'd say it, and proudly cite some study, or test standard used.
I also find it interesting that their first complete applications are Neons and PT Cruisers.
The product may work as advertised. I don't think I'll try it just yet.
 Post subject: Hotter spark
PostPosted: Thu Aug 11, 2005 8:17 am
If the system can put out a higher voltage for the spark it could jump a
larger gap. The spark plug gap could be widened and provide a hotter
spark. Could that ignite the fuel more completely? Thus resulting in better
gas mileage.
PostPosted: Thu Aug 11, 2005 11:19 am
funny, but i recall using a labscope to diagnose ingition concerns in the past and the pattern they show for the direct hits ignition looks an awful lot like a bad plug or plugwire. i wonder if their setup runs similarly.
a bad/worn plug will case the wire to breakdown prematurely, and so-on upstream in the ignition system.
i'm no engineer, but it just sounds bad.
-james
PostPosted: Thu Aug 11, 2005 9:16 pm
It IS bad.
It taxes not only the wires, but the coil packs, and shortens their life.
The reason they describe the spark duration as being shorter is not because this is an intended outcome, but because that is the only way the condenser can concentrate that power, is by shortening its duration. It cannot generate electricity.
 Post subject: Guinea pigs wanted!
PostPosted: Fri Aug 12, 2005 6:23 am
Color me perfectly willing to let someone else spend their money on these. Then please come back with real numbers for before and after MPG and E.T. :!:
 Post subject: Re: Guinea pigs wanted!
PostPosted: Wed Dec 14, 2005 12:15 am
Some of te mines out in the west, at least a few years back, liked to use these because they wouldn't interfere with the electric detonators. Pretty muck all the small engines used for mud pumps, generators are diesel. but some still use narural gas and compressed air
1967 D100 /225
Some of us catch on slow, and some of us don't.
PostPosted: Wed Dec 14, 2005 9:54 am
I have one of those on an old lawnmower, and it quit fouling plugs(so often)
That is the only advantage I have found with those things.
Seems to run the plug hotter, or maybe it just builds up enough voltage to jump "thru" the oily goo on the plug????? :?
Users browsing this forum: Ahrefs [Bot], Google [Bot] and 9 guests
