It is currently Fri Oct 09, 2026 7:13 am
PostPosted: Thu Aug 25, 2005 2:22 pm
I changed my oil on the slant the other day, after I was having problems with the oil light coming on.
Changing the filter, and refilling with 20w50 seems to have fixed the oil light problem.
But I noticed that the old oil smells a lot like gasoline.
Is this an indicator of other problems ? Maybe worn rings, or carb to rich ?
Thanks
PostPosted: Thu Aug 25, 2005 2:32 pm
I would check fuel pump. Mine was doing that.
82 D150 Slant6 Shorty
http://www.cardomain.com/ride/658846
PostPosted: Thu Aug 25, 2005 2:52 pm
Yep, a torn fuel pump diaphragm is the prime suspect when the oil begins to smell of gasoline.
PostPosted: Thu Aug 25, 2005 3:36 pm
Actually that would not surprise me..
This car is from california, and has spent many years sitting in a garage and only being driven once in a while.
I have noticed that everything rubber on the car is disinigrating.
Window seals are hard, dry, and falling apart, everything rubber in the front suspension was falling apart (i've already done that rebuild), and I have several oil leaks from the engine and tranny that are probably due to old dried out seals.
Is there really any way to check the pump for this ? or am I just going to have to replace it and then keep checking the oil for gas smell. ?
PostPosted: Thu Aug 25, 2005 3:59 pm
You can pull the pump, connect the inlet to a hose leading into a can of gasoline, cap off the outlet and operate the pump lever against the floor (or with a big vise) and watch for the squirt of gasoline past the operating lever, but for all that effort and the low cost of fuel pumps...just replace the pump! Remember, California has for the past decade or so required gasoline formulations that tend to attack older cars' original fuel system elastomers.
PostPosted: Fri Aug 26, 2005 7:23 am
Thanks Dan, I think your probably right, I'll just pick up a new pump and change it out this weekend.
PostPosted: Fri Aug 26, 2005 4:00 pm
And change the oil afterwords...gas isnt helping them bearings any.
Users browsing this forum: 66darter, Bing [Bot], Google [Bot] and 17 guests
