It is currently Mon Nov 23, 2026 12:11 pm
PostPosted: Fri Nov 25, 2005 1:34 pm
Car Model: 71 Dodge D100 64 Plymouth Valiant Wagon
My electronic ignition kit from my friends on Ebay arrived without instructions. It all looks pretty simple, except for three wires.
Where does the blue striped w/yellow wire go?
Where does the green striped w/ red wire go?
Where does the black striped w/ yellow go?
Thanks very much and hope you all had a great T' giving,
Joe
Joe Hoppe
71 D100 225 Super Six 727 AT on 2008 Crown Vic CopCar frame
64 Valiant Wagon 225 904 AT 3:23 8.75"
PostPosted: Fri Nov 25, 2005 4:44 pm
The black w/yellow tracer goes to the negitive post of the coil, the blue w/yellow tracer goes to the run side of the ballast resister. Green w/red tracer is not used. Just cut and cover it with tape. This is assuming your using this with a single ballast resister, not the dual resister. Yes, you can use a 5 pin ECU with a single resister.
PostPosted: Sun Nov 27, 2005 8:52 am
Thanks, Eric. We'll see how that works.
Joe
Joe Hoppe
Users browsing this forum: Bing [Bot], Craig Hodge and 10 guests
