It is currently Thu May 07, 2026 6:56 pm
 Post subject: Steering box help
PostPosted: Fri Sep 09, 2005 8:56 am
Car Model: 1962 Lancer 770
Hey all,
A friend is sending me a manual steering box from a 67 Dart convertible, and I was wondering what year the boxes changed from the older ball bearings to the newer needle bearings. I need to order a rebuild kit for it and wanted to make sure I got the right parts.
I'm going to be putting a 20:1 gear in this one.
Thanks!
PostPosted: Fri Sep 09, 2005 10:30 am
My understanding of it is that all years of /6 boxes had bushings and all years of v8 boxes had needle bearings, but I could be wrong.
PostPosted: Fri Sep 09, 2005 11:04 am
mcnoople's right; most of the \6 boxes had bushings and most of the V8 boxes had bearings.
I put the 20:1 chuck in my original '62 (bushing) box; it works great.
PostPosted: Fri Sep 09, 2005 1:16 pm
Here's a question for the experienced. Can you install bearings in a box that originally had bushings? Would it require machining? Is machining even possible or worth the effort?
PostPosted: Fri Sep 09, 2005 1:50 pm
Housing casting is different.
PostPosted: Fri Sep 09, 2005 3:16 pm
great that makes life easy ;-) Thanks!
MJ
