It is currently Thu Apr 30, 2026 3:55 pm
PostPosted: Wed Sep 21, 2005 2:38 pm
Im looking for advice on where to begin with porting and polishing a slant 6 head, what works best, a dremel??? what stones???
PostPosted: Wed Sep 21, 2005 3:06 pm
Start by taking the head off the engine.
I used a dremmel with a tungsten carbide cutter and several different stones.
 Post subject: Links.........
PostPosted: Wed Sep 21, 2005 8:08 pm
http://www.sa-motorsports.com/diyport.shtm
http://www.racetech.com.au/custom.htm
Of the 2, the first is better for the DIYer...........
PostPosted: Wed Sep 21, 2005 8:33 pm
I have been working on mine... the exhaust first. anyway I am using a die grinder with 6" long carbide bits I got from summit racing. They seam to work well. when I am done with the cutters I will "polish" with 60 grit sandpaper rolls.
1966 Signet
Turbo Slant Six
 Post subject: So now.....
PostPosted: Wed Oct 12, 2005 12:41 pm
Well, thanks for the insight. What are some suggestions on what to look
out for or be careful of???
PostPosted: Wed Oct 12, 2005 8:02 pm
Do not take any material off the floors. Blend in the transition from the valve seat to the port. Remove most of the valve guide bosses to smooth the port - more on the exh side than int.
Do not remove the squared section between int/exh ports or you will hit water. You can blend it some, but don't get carried away.
These are points from Cameron Tilley and Mike Jeffrey that I just did on my head. I made too many other changes to really tell much, but it does seem to rev more freely to high rpm now.
 Post subject: Re: Links.........
PostPosted: Wed Oct 26, 2005 11:10 am
:shock: nice link man, i was reading the second link about the porting and how bigger isnt always better :shock: very intresting
Cuda Progress :D
The dart as it sits now :(
 Post subject: any pics
PostPosted: Sat Feb 11, 2006 7:50 pm
Does anybody have any pics of a slant six head thats been ported??
Lou, When you said dont port the floors- do you mean dont port intake
and exhaust floors or just one or the other??
thanks!
PostPosted: Sat Feb 11, 2006 7:59 pm
Car Model: 1962 Lancer 770
rob how's that coming anyway? Have you taken any pics of that? I'm interested to hear how the progress is going.
Menko
PostPosted: Sun Feb 12, 2006 7:11 am
The floors means the bottoms of the port runners as you look at the head on the engine. My comment above means don't remove any material (except casting flash) from the floors on ANY of the ports.
Hope it's going well!
