How do I begin porting a slant head?
https://slantsix.org/forum/viewtopic.php?t=14457
Page 1 of 1
Author:  featherduster76 [ Wed Sep 21, 2005 2:38 pm ]
Post subject:  How do I begin porting a slant head?
Im looking for advice on where to begin with porting and polishing a slant 6 head, what works best, a dremel??? what stones???
Author:  70valiant [ Wed Sep 21, 2005 3:06 pm ]
Start by taking the head off the engine.
I used a dremmel with a tungsten carbide cutter and several different stones.
Author:  emsvitil [ Wed Sep 21, 2005 8:08 pm ]
Post subject:  Links.........
http://www.sa-motorsports.com/diyport.shtm
http://www.racetech.com.au/custom.htm
Of the 2, the first is better for the DIYer...........
Author:  Rob64GT [ Wed Sep 21, 2005 8:33 pm ]
I have been working on mine... the exhaust first. anyway I am using a die grinder with 6" long carbide bits I got from summit racing. They seam to work well. when I am done with the cutters I will "polish" with 60 grit sandpaper rolls.
Author:  featherduster76 [ Wed Oct 12, 2005 12:41 pm ]
Post subject:  So now.....
Well, thanks for the insight. What are some suggestions on what to look
out for or be careful of???
Author:  Dart270 [ Wed Oct 12, 2005 8:02 pm ]
Do not take any material off the floors. Blend in the transition from the valve seat to the port. Remove most of the valve guide bosses to smooth the port - more on the exh side than int.
Do not remove the squared section between int/exh ports or you will hit water. You can blend it some, but don't get carried away.
These are points from Cameron Tilley and Mike Jeffrey that I just did on my head. I made too many other changes to really tell much, but it does seem to rev more freely to high rpm now.
Author:  1966 dart wagon [ Wed Oct 26, 2005 11:10 am ]
Post subject:  Re: Links.........
:shock: nice link man, i was reading the second link about the porting and how bigger isnt always better :shock: very intresting
Author:  featherduster76 [ Sat Feb 11, 2006 7:50 pm ]
Post subject:  any pics
Does anybody have any pics of a slant six head thats been ported??
Lou, When you said dont port the floors- do you mean dont port intake
and exhaust floors or just one or the other??
thanks!
Author:  NewLancerMan [ Sat Feb 11, 2006 7:59 pm ]
rob how's that coming anyway? Have you taken any pics of that? I'm interested to hear how the progress is going.
Menko
Author:  Dart270 [ Sun Feb 12, 2006 7:11 am ]
The floors means the bottoms of the port runners as you look at the head on the engine. My comment above means don't remove any material (except casting flash) from the floors on ANY of the ports.
Hope it's going well!
