| slant 6 stock intake and headers compatability https://slantsix.org/forum/viewtopic.php?t=14578 |
| Author: | demented_greaser [ Sat Oct 01, 2005 10:49 pm ] |
| Post subject: | slant 6 stock intake and headers compatability |
I have a 73 motor with a cracked exhaust manifold, i want to put headers on instead of a stock replacement manifold, do i also need to change out the intake if i use headers? -alex |
| Author: | carrigan #3 [ Sat Oct 01, 2005 11:02 pm ] |
from what i gather it would depend on what kind of headers ur lookin at...research is good |
| Author: | 73dart_swinger [ Sun Oct 02, 2005 5:10 pm ] |
no, you can use the stock intake. |
| Author: | zedpapa [ Sun Oct 02, 2005 9:21 pm ] |
| Post subject: | headers |
yes you can use the stock intake. however, if you use the clifford headers, the flanges are different thicknesses. you need to use a thick and soft manifold gasket to get it to seal up. i have a leak on #4 that won't seal up because the difference in thickness. zedpapa |
| Author: | Charrlie_S [ Mon Oct 03, 2005 5:38 pm ] |
4 sets of Clifford headers, I have, are all 1/2 inch flange. The MP headers I have seen, have a thinner flange with, (I think) a nut welded on, where the triangle washers go. |
| Author: | sixty4dartgt [ Mon Oct 03, 2005 11:29 pm ] |
My Clifford headers have the thick flange also. I am using an Offy intake. I don't know if it is different than stock. |
| Author: | Charrlie_S [ Tue Oct 04, 2005 4:10 am ] |
The Offie, Clifford and factory manifolds, I have in stock, all have the same flange thichness, within manucturing tolorances. |
| Author: | 70valiant [ Tue Oct 04, 2005 2:22 pm ] |
my clifford headers hava a thinner flange than my clifford 4 barrel intake. I ground around an 1/8" off of one side of the triangle washers to make everything seal up nicely. |
| Author: | scamp 72 [ Mon Oct 10, 2005 6:18 am ] |
On my mopar headers I welded 3/16" spacers on the flanges where the triangle washers make contact.This brought it up to the same thickness as my offy intake.It seals no problem with a Mr Gasket 320 gasket. |
