It is currently Wed Nov 18, 2026 12:27 am
PostPosted: Sat Oct 01, 2005 10:49 pm
I have a 73 motor with a cracked exhaust manifold, i want to put headers on instead of a stock replacement manifold, do i also need to change out the intake if i use headers?
-alex
mopar or no car!!!
PostPosted: Sat Oct 01, 2005 11:02 pm
from what i gather it would depend on what kind of headers ur lookin at...research is good
My Dart
GO VOLS!
It's not rocket science, we're just splitting atoms.
PostPosted: Sun Oct 02, 2005 5:10 pm
no, you can use the stock intake.
 Post subject: headers
PostPosted: Sun Oct 02, 2005 9:21 pm
yes you can use the stock intake. however, if you use the clifford headers, the flanges are different thicknesses. you need to use a thick and soft manifold gasket to get it to seal up. i have a leak on #4 that won't seal up because the difference in thickness.
zedpapa
soon to have 5 gears!!!
PostPosted: Mon Oct 03, 2005 5:38 pm
4 sets of Clifford headers, I have, are all 1/2 inch flange. The MP headers I have seen, have a thinner flange with, (I think) a nut welded on, where the triangle washers go.
PostPosted: Mon Oct 03, 2005 11:29 pm
My Clifford headers have the thick flange also. I am using an Offy intake. I don't know if it is different than stock.
"Nothing in all creation is hidden from God's sight. Everything is uncovered and laid bare before the eyes of Him to whom we must give account."
PostPosted: Tue Oct 04, 2005 4:10 am
The Offie, Clifford and factory manifolds, I have in stock, all have the same flange thichness, within manucturing tolorances.
PostPosted: Tue Oct 04, 2005 2:22 pm
my clifford headers hava a thinner flange than my clifford 4 barrel intake.
I ground around an 1/8" off of one side of the triangle washers to make everything seal up nicely.
PostPosted: Mon Oct 10, 2005 6:18 am
On my mopar headers I welded 3/16" spacers on the flanges where the triangle washers make contact.This brought it up to the same thickness as my offy intake.It seals no problem with a Mr Gasket 320 gasket.
72 Scamp dual 1 brl
Users browsing this forum: DuckDuckGo [Bot] and 8 guests
