It is currently Thu Nov 19, 2026 9:33 pm
PostPosted: Wed Oct 05, 2005 12:04 pm
I was looking over Doug's Article http://www.slantsix.org/articles/stroking/stroking.htm
and I was wondering if anybody has looked at 2.0 or 2.4 liter pistons for a slant?
Check this out http://importperformanceparts.net/impor ... ysler.html
I don't know what the pin diameter needs to be, or the compression height of the pistons. However, it may be close. Whatta ya think?
PostPosted: Wed Oct 05, 2005 2:00 pm
The Mopar 2.0 or 2.4 use a shorter compression height (around 1.42"?) than the 2.2 pistons (around 1.59"). Look at an online piston catalog like Keith Black or Silvolite for dimensions. With a stroked crank and/or decked block, you could use those pistons.
PostPosted: Wed Oct 05, 2005 2:19 pm
Maybe Rayman will pop in here, but he is using 2.4 pistons on custom 7.12" rods in his motor. Comp is relatively low though. :shock:
PostPosted: Wed Oct 05, 2005 3:23 pm
I wonder if there are other metric pistons that might be a better fit. Any other ideas?
The problem is that even with longer (198) rods, the motor was designed for old fashioned pistons, with a taller compression height. I don't think that many modern motors would use pistons like that anymore, due to the weight and pollution problems with rings that sit lower on the piston.
thanks,
 Post subject: 2.4 pistons
PostPosted: Wed Oct 05, 2005 3:24 pm
Yes. I am using those pistons ( Wiseco Forgings ) but they were perfectly suited to my application as I wanted a lower than std C/R. My combo used a 7.120' long rod and the 2.4 piston ( Comp Height 1.4' ) @ 7.88:1 CR .....
Ray
Users browsing this forum: DuckDuckGo [Bot] and 3 guests
