| long rod engine-piston question https://slantsix.org/forum/viewtopic.php?t=14623 |
| Author: | gmader [ Wed Oct 05, 2005 12:04 pm ] |
| Post subject: | long rod engine-piston question |
I was looking over Doug's Article http://www.slantsix.org/articles/stroking/stroking.htm and I was wondering if anybody has looked at 2.0 or 2.4 liter pistons for a slant? Check this out http://importperformanceparts.net/impor ... ysler.html I don't know what the pin diameter needs to be, or the compression height of the pistons. However, it may be close. Whatta ya think? Greg |
| Author: | Dart270 [ Wed Oct 05, 2005 2:00 pm ] |
The Mopar 2.0 or 2.4 use a shorter compression height (around 1.42"?) than the 2.2 pistons (around 1.59"). Look at an online piston catalog like Keith Black or Silvolite for dimensions. With a stroked crank and/or decked block, you could use those pistons. Lou |
| Author: | slantzilla [ Wed Oct 05, 2005 2:19 pm ] |
Maybe Rayman will pop in here, but he is using 2.4 pistons on custom 7.12" rods in his motor. Comp is relatively low though. |
| Author: | gmader [ Wed Oct 05, 2005 3:23 pm ] |
| Post subject: | OK, so this is a not quite a bolt in |
I wonder if there are other metric pistons that might be a better fit. Any other ideas? The problem is that even with longer (198) rods, the motor was designed for old fashioned pistons, with a taller compression height. I don't think that many modern motors would use pistons like that anymore, due to the weight and pollution problems with rings that sit lower on the piston. thanks, Greg |
| Author: | Rayman440 [ Wed Oct 05, 2005 3:24 pm ] |
| Post subject: | 2.4 pistons |
Yes. I am using those pistons ( Wiseco Forgings ) but they were perfectly suited to my application as I wanted a lower than std C/R. My combo used a 7.120' long rod and the 2.4 piston ( Comp Height 1.4' ) @ 7.88:1 CR ..... Ray |
