It is currently Wed Nov 18, 2026 11:41 am
 Post subject: woah!!!!
PostPosted: Mon Aug 18, 2003 3:22 pm
I just found out i have no crankshaft puley bolt! what should i do?is this a big problem???HELP!!! :cry:
PostPosted: Mon Aug 18, 2003 3:33 pm
Lot's of Slants didn't come with them. I added one to my '65 so that I could turn it over easier when timing the disributor and adjusting valves.
"Former Owner" of '65 Barracuda, 225, Auto, MP 2bbl intake, MP cam, Dutra Duals. Presently Moparless.
 Post subject: No Worrys
PostPosted: Mon Aug 18, 2003 3:58 pm
Nothing to worry about. I don't have one on mine either. 8)
PostPosted: Mon Aug 18, 2003 7:50 pm
If you really have to have one, go to a harware store and buy a 3/4 fineX1-1/4" bolt and a thick washer. :shock:
PostPosted: Tue Aug 19, 2003 7:55 pm
I grabbed mine form a small block V8, same size as a slant and easier to find in the junk yard. While I recognize that it isn't needed, I couldn't figure out how to re-install my balancer without one.
PostPosted: Tue Aug 19, 2003 8:07 pm
There is a tool called a harmonic balancer installer, pretty much a long rod with a bearing and some washers. Off the top of my head I know mac tools has one because thats the one I used before, I'm sure you can get others for cheaper.
PostPosted: Tue Aug 19, 2003 9:04 pm
A long 3/4 fine bolt, a nut, and a couple flat washers will work too. :shock:
PostPosted: Tue Aug 19, 2003 10:27 pm
Slantzilla, yea, infact before I found the tool in the garage I just "carefully" banged the balancer on with a mallet, making sure I only hit it in the center. Took forever and a day but it works.
PostPosted: Wed Aug 20, 2003 12:14 am
Ouch... if you have to "bang one on", be sure to stand the engine on end so the crank's rear flange is solid to the floor, doing this keeps the shock off the #3 main bearing thrust surface.
If the engine is in the car, find a bolt or the install tool.
PostPosted: Wed Aug 20, 2003 12:19 am
Doc, I'll keep that in mind for next time. The engine was horizontal on a stand. After the engine was installed in the car and I found the tool, I used it to make sure it was completely seated.
 Post subject: crankshaft pully bolts
PostPosted: Fri Nov 04, 2005 7:57 pm
Long Time No See....
So, as I understand it, that hugmongus important-looking bolt (1.25inch)on the front of my engine's crankshaft is only important for turning the engine over or bolting on a harmonic balancer?
(...I just finished pulling my '87s engine and replacing it with an '84 engine...)
Does it need a torque value? How about those three little bolts that actually hold the pully on?
1987 Dodge Ram 100 Custom
Slant 6
833
...gonna keep this one...
PostPosted: Fri Nov 04, 2005 8:14 pm
Correct. The crankshaft pulley/vibration damper/harmonic balancer (three names, same part) is a keyed interference fit on the crank snout. It will not fall off without a bolt. As has been mentioned many (actually, most) slant-6s came from the factory without a bolt in this location. It is not necessary.
PostPosted: Fri Nov 04, 2005 8:54 pm
I got into a arguement the other day with a friend when my slant was stuck...He said to simply turn it over with a powerbar on the balancer...I have three parts cars here and of the 4 slant 6's none had the bolt...He told me someone must have stolen them :roll:
PostPosted: Sat Nov 05, 2005 8:26 pm
...huh...both my '87 and my '84 had those bolts...I torqued that bugger to 75FTLBs just in case...but lacking experience, plus the manual says nothing...I guess 20 FTLBs for those three little bolts?...you know, the ones that actually hold the pully in place?
Slant 6
833
Users browsing this forum: No registered users and 15 guests
