It is currently Fri Nov 20, 2026 1:47 am
PostPosted: Mon Nov 07, 2005 9:15 pm
I ask this ´cause a couple of friends that work on performance shops toll me that I can close the acces of my PCV valve in the carb and put a small air cleaner in the Valve Cover in the place of PCV valve and that will make my engine look more "sport" and will not make adverse performance.
How much truth is on that? will a cylinder run lean or will it not make any effect?, as I know PCV valve just make exchange of carter gases to mix with carburator gases and prevent some polution.
Mopar Muscle is well defend by Slant Six!
Valiant Duster 1971
PostPosted: Mon Nov 07, 2005 9:18 pm
The PCV valve can't be easily deleted. In addition to taking care of pollution, it removes excess vapors from the crank case; without it, you can develop a positive pressure situation, eventually blowing oil seals and gaskets.
PostPosted: Mon Nov 07, 2005 9:19 pm
Yeah, Cstryker is right. The PCV valve does not hurt performance, it helps it! Leave it in place.
PostPosted: Mon Nov 07, 2005 9:26 pm
Ok, but a open way to get and evacuate air will not make the work? I got a small air filter (originally for remplace VW oil cap) that I can adapt to fit in place of PCV valve in the Valve Cover, and I can get another to put in the carb. But I still don´t know how good is this idea.
Valiant Duster 1971
PostPosted: Mon Nov 07, 2005 9:38 pm
No, it will not. Your engine will get very much dirtier (and more water) in the crankcase. Leave the system alone! It's not hurting anything and it's helping you!
Not good, don't do it.
PostPosted: Mon Nov 07, 2005 9:43 pm
Ok SSDan I undestand, don´t get angry. I will leave that valve alone and say hi to it everytime I open the hood.
Valiant Duster 1971
PostPosted: Tue Nov 08, 2005 3:17 am
Car Model: '23 T-bucket
By the way, Avenger.....next time your under the hood, take the valve out and shake it. If it rattles, your ok, if it doesn't get a new one. A stuck pcv valve will act like a closed system, and cause crankcase pressurization problems.
Roger
PostPosted: Tue Nov 08, 2005 4:26 am
Just for your info. Back in the "old days" in stock eliminator racing, we used to gut the PCV valve to get more air flow thru it. Gave the effect of a slightly larger carb. The carb did have to be rejetted for this to work, or it would run too lean. My advise, leave the PVC on the engine in good working order. Make sure the hose and the fitting at the carb are not plugged up.
Users browsing this forum: Amazon [Bot], Bing [Bot] and 7 guests
