It is currently Sat Nov 21, 2026 11:23 pm
PostPosted: Tue Nov 08, 2005 7:12 am
Anyone know how deep those engine numbers are stamped?
Will cutting the deck .045 remove the engine numbers?
I ask because I just got my 170 back from the machinist and he
claims to have cut the deck .045 to get a -.010 deck height like I
asked. However the engine numbers are still there and easily legible.
Is this machinist feeding me a line?
PostPosted: Tue Nov 08, 2005 8:44 am
I would be skeptical. A 170 is a "zero" deck motor. Everyone I have seen, needs some cutting to get to zero, but the most I have seen, myself, is about .030, and that would bring it to zero.
All of the 170 motors I have, that have had the decks cut, were brought to .005, and the numbers are gone.
What you need to do, is put a crank, rod, and piston assy, in the block and measure the deck. If it is where you want it, what is the problem?
PostPosted: Tue Nov 08, 2005 9:59 am
There should be machining marks on the deck if it had been cut, shouldn't there? :?:
 Post subject: I want it My Way !
PostPosted: Tue Nov 08, 2005 2:28 pm
I did not have the time to tear into it myself, so I hired a shop to
rebuild it to my build sheet. The pistons they were going to use have
a compression height less than stock. The motor was already around
-.060 deck height. This measurement is a ballpark, since my
measuring tools are not super precise.
I wanted the deck height around -.005 (-.010 is acceptable)
And I wanted the head cut a small amount to get a static
compression ratio of around 9:1 for the cam going in the motor.
One thing I am afraid of is the shop may have cut the entire cut
from the head instead of .045 from the block and .030 from the head.
When this head gets moved back onto one of my stocker motors later
it will cause me grief if I think it is cut .030 but is really cut .075
Guess my real beef is what happened to "the customer is always right".
It is my cash - I should get it the way I asked for it. I may need to
tear this motor down to measure all the parts, just to see what I
have now. Thanks for the rant ...
Sounds like I should have machining marks instead of numbers -
Which is what I would expect.
PostPosted: Tue Nov 08, 2005 2:49 pm
no way are those numbers stamped .045 deep. Looks like the machinist decided he knew more than you.
PostPosted: Tue Nov 08, 2005 2:58 pm
Too late now, but it sounds like you're better off taking the parts in one at a time so you can get what you want done, rather than being second-quessed................
 Post subject: only skimmed
PostPosted: Sun Nov 13, 2005 11:08 pm
The head and block were only skimmed to make them flat -
I took the head off to measure the chamber volume and the
deck height. The deck hieght is still about .066 down the bore
and the chamber volume is now 60 cc. I did not measure it
before, so I don't have a starting reference on the volume.
The bore is .030 over with flat top pistons.
Now I get to do the numbers again for the static compression
ratio and decide to find a new machinist or put it together the
way it is.
This 170 is going to be my (clifford ) hyperpak motor, with a
260M cliifford cam,and a 390 cfm 4 bbl. Cam has .290 lift
and 210 degrees duration at .050. Was not intended to be
a radical buid up - just a streetable 170. How low can the
compression ratio go before the cam makes the 170 a complete
dog at low rpm?
PostPosted: Mon Nov 14, 2005 7:14 am
You can run stock comp with that cam, no problem. It's almost a stock cam anyway, actually.
I got burned by a machinist once who didn't cut my head and took my money. I always make a reference mark or measurement before sending out now to verify they've done it.
PostPosted: Mon Nov 14, 2005 7:52 am
When I had my head finished last summer the machine shop decided to add HUGE valves to my head. I had valves and springs already so told the shop I wasn t paying for the new valves, springs etc. They said I had to since they had cut the head for them. I said "keep the head,,,Ill sart over somewhere else" I went to pick up my block crank head etc and go elsewhere,,,only to find my head with hardened seats installed to fit my valves. I said "Cool!,,,but thats still not what I asked for" The hardened seats were no charge.
It pays to have a plan and stick to it,,,and be harsh if necessary. These guys knew they were risking all the "fleet" work they do for our business.
 Post subject: CR 7.2 to 1
PostPosted: Mon Nov 14, 2005 11:01 am
The numbers say the static compression ratio is 7.2 : 1
That is a bit lower than the 9:1 for which I was aiming.
I think that is even lower than the stock compression ratio.
Did I measure the deck height correctly? I put a straightedge
on the head gasket surface and slipped feeler gauges between
the piston top and the straight edge when the piston was a the
top of its travel. The .021, .022, and .023 all fit at once - so I
call it .066 down the bore deck height. Seems right to me.
PostPosted: Mon Nov 14, 2005 11:13 am
If you have the head off, I think you need to take it back and insist they mill it right.
Assuming the piston was at TDC, that is a valid way to measure within a few thousandths. It does seem very far off for a stock motor, though. Have you tried rotating the motor to allow fewer shims to fit in the gap?
Users browsing this forum: Amazon [Bot], Google [Bot] and 8 guests
