It is currently Sat Nov 21, 2026 5:25 pm
 Post subject: oil pump blues
PostPosted: Fri Nov 11, 2005 7:34 pm
Car Model: '63 Dart GT Convertible
Replaced my oil pump about 6 mths. ago. Now the damn thang don't work no more. Ticks me off. What I want to know is, What brand of pump do you use? I got this one from O'Reilly. Don't want to do that again but may have to bcause of warranty. Who uses what in high performance engines? How well do they hold up?
ifyoubegintothinkyou'relosingcontrol...it'salreadygone
PostPosted: Fri Nov 11, 2005 7:42 pm
I've got a stock 5 bolt pump that Doug blueprinted on my motor. I gave $32.95 for it at Autozone. :shock:
PostPosted: Fri Nov 11, 2005 8:31 pm
After having a rebuilt pump last 1 week in my new motor(hooped the crank) I went to a 100,000 mile stock 69 pump that I freshened up. Lower oil pressure and volumne = less load on pump gear. I also switched to 5w/30 oil for winter.
 Post subject: Re: oil pump blues
PostPosted: Fri Nov 11, 2005 8:40 pm
What is the problem, low oil pressure or no oil pressure?
Is the gear showing any wear?
There is not a lot to go wrong with a SL6 oil pump, if you are getting low oil pressure it could be worn engine bearing instead of a worn oil pump.
PostPosted: Fri Nov 11, 2005 9:38 pm
Doug, what's been your "find rate" of sticky/stuck oil pressure relief valves?
PostPosted: Sat Nov 12, 2005 1:07 am
Just a quick note re relief valves. My factory Dodge Truck Australian workshop manual recommends annual removal and cleaning of teh relief valve on slant engines, more frequently under sever conditions. My truck had lots of crud/varnish in the relief valve bore when I cleaned it out, and I picked up 10psi at idle( mechanical oil pressure gauge).
Regards, Andrew.
PostPosted: Sat Nov 12, 2005 8:43 am
Yeah...I think this problem isn't as major as it used to be, for modern oils run considerably cleaner than older oils. But it's still a potential issue, and it'll be a lot easier for the OP to remove the relief valve cap, pull the valve shuttle and give the shuttle and bore a good cleandown with carburetor cleaner than it will for him to replace the pump. It's worth a try!
PostPosted: Sat Nov 12, 2005 11:33 am
It is not often that I find a stuck or sticky releif valve, the thing lives in oil and has a pretty stiff spring behind it. The ones I have found stick open had a piece of old valve stem seal or broken distributor gear jammed into them.
As noted, it is easy to check so pull it and clean as noted above.
 Post subject: under pressure
PostPosted: Sat Nov 12, 2005 12:26 pm
The problem is NO pressure, none.Haven't had a chance to check anything yet, thanx.
Users browsing this forum: Bing [Bot] and 11 guests
