| Having trouble finding wheel bearings--KH 4 piston discs https://slantsix.org/forum/viewtopic.php?t=15050 |
| Author: | NewLancerMan [ Wed Nov 16, 2005 6:58 pm ] |
| Post subject: | Having trouble finding wheel bearings--KH 4 piston discs |
Hey all, I've been looking at partsamerica.com and rockauto.com and a few other sources and not been able to find a part number for the inner and outer wheel bearings for my disc brake swap. I find 9". 10" and 11" brakes spec'd, so i'm wondering if the 11" is the discs. I Assume it is, but dont want to end up with the wrong stuff. From PartsAmerica I find: Outer: p/n is: "SKF BR2 CR BEARING" #BR2 Inner: Seal p/n "BCA Bearings SEAL #8121S Anyone happen to have any cross reference for these numbers? I'd appreciate it greatly! Thanks MJ |
| Author: | skraecken [ Thu Nov 17, 2005 1:06 pm ] |
If you can measure the bearings, I think I can provide you with the numbers. Or, if you know what car the discbrakes come from. |
| Author: | Pierre [ Thu Nov 17, 2005 1:26 pm ] |
I ran into the same situation you did when converting to KH. I'm 99% sure 10/11/kh setups used same bearing. I'm looking for my post on moparts because I know someone there confirmed the answer for me. |
| Author: | Pierre [ Thu Nov 17, 2005 2:01 pm ] |
No luck, sorry. I remember finding one parts book that lists the bearings as 10/11/discs but dang if I can remember which. I believe others on here still use the KH setup so they are bound to chime in soon enough on this thread. |
| Author: | Dart270 [ Thu Nov 17, 2005 2:53 pm ] |
There were no 11" drums on A-bodies, so the listing must be for the KH discs, which are 11" diameter. I just bought a full set of front brngs and seals from NAPA about 3 mo ago and I don't remember any issues. I'll try to dig up numbers... Lou |
| Author: | SlantSixDan [ Fri Nov 18, 2005 8:54 am ] |
I've just confirmed: Same bearings on discs and 10" front drums. |
| Author: | NewLancerMan [ Fri Nov 18, 2005 9:54 am ] |
a |
| Author: | NewLancerMan [ Fri Nov 18, 2005 9:55 am ] |
Thanks Lou and Pierre for looking, I appreciate it! Ok so here's what I'm coming up with for outer and inners...maybe you guys can confirm: (BTW donor car =1972 Dart) Inner: BCA A6 Outer: BCA A2 both are spec'd for 10" or 11" brakes on one site, and for taper bearing set on the other. I'm guessing these are the right ones? yea or nea?! MJ |
| Author: | skraecken [ Fri Nov 18, 2005 10:06 am ] |
My SKF automotive service list stop in -69. I dont think that the bearings are the same but -69 with diskbrakes: inner K-LM 67048/67010, outer K-LM 11949/11910 (Timken uses the same numbers) |
| Author: | Charrlie_S [ Fri Nov 18, 2005 4:17 pm ] |
I came up with the A-2 and A-6 bearing for the K-H discs, also. |
| Author: | NewLancerMan [ Fri Nov 18, 2005 6:05 pm ] |
Thanks Charlie for the confirmation. I'll order them Monday. Just didn't want to mail order a slew of parts and then have to return bearings because I ordered the wrong ones! MJ |
