It is currently Tue Jun 09, 2026 8:46 pm
PostPosted: Sun Dec 04, 2005 5:08 pm
Finally got around to adjusting the valves (with 16000 miles I didn't think they'd be that far off) and car runs much better.....
Before:
Slightly rough idle when fully warmed up (I noticed, nobody else seemed to)
Slight low throttle surge until warmed up
After:
Idle smooth
no surge
peppier
All the intakes were loose;
amount off varied from .001 to .006
....1......2.......3......4.......5......6
(.001, .006, .006, .004, .006, .003)
or
(.011, .016, .016, .014, .016, .013)
Most of the exhausts were loose;
amount off varied from -.007(tight) to .006
(.002, .006, .006, .005, .001, -.007)
or
(.022, .026, .026, .025, .021, .013)
Other than cyl 6, (which I think was a goof by someone since intake and exhaust are the same), valve recession doesn't seem to be a problem
PostPosted: Sun Dec 04, 2005 9:11 pm
So, did you adjust to stock specs, or tighten them up some? I tightened up my intake to .009" and exhaust to .018". Made a big difference according to my "seat of the pants dyno".
PostPosted: Sun Dec 04, 2005 10:02 pm
Stock
I can see the peppy part, as now my cam has slightly longer duration.
But I don't get the surge or roughness (not complaining), as I thought 'tight' valves would cause roughness, and ignition timing & lean carb surge.
As an aside, does anyone know the relationship between duration and lash? How much more duration for a given decrease in lash.
PostPosted: Wed Dec 07, 2005 7:58 pm
Eric, everything is good with the .09 .18 so far? If so I might try that this spring when I change carbs. I just don't want to do anything to put stress on the valves. I have to remember this car is supposed to last long more than its supposed to drive fast.
God took you away, then brought you back to me.
Users browsing this forum: Ahrefs [Bot] and 6 guests
