It is currently Sun Nov 22, 2026 10:10 am
 Post subject: cam installation help.
PostPosted: Fri Nov 18, 2005 1:49 pm
hi, just ordered a new custom grind from comp cams for my turbo dart project. never installed a cam on a /6 or any motor for that fact. Just had a few q's.
Can you use any old degreeing wheel for any application?
what would i need in addition in order for the motor to run fine. new lifters, springs? some recommend 340 springs but i'm on a budget.
also, couldnt you just find TDC easier if you had the head off anyways.
i think the cams around .236 .240 -.456 .462
