It is currently Thu May 07, 2026 8:12 pm
 Post subject: lug nuts
PostPosted: Thu Nov 24, 2005 5:50 am
Car Model: 1974 W100; 72 Dart
i purchased a set of SBP cragars from ebay. the guy only had 11 lug nuts. (obviously) need 9 more. i can't locate them locally. the tire shops and chain stores only have lugs whose shanks are bigger. (diameter of shank, not length)
i can turn the lugs down so they will fit the wheel, but i'd like to find a set of the proper ones. anyone out there have an idea about where i can find OLD style Cragar lugs?
sb
PostPosted: Thu Nov 24, 2005 6:49 am
Try www.cragarwheels.com
PostPosted: Thu Nov 24, 2005 8:06 am
If that doesn't work, try here:
http://www.prestigewheel.com/cgi-bin/co ... n&key=5203
...you may have to ream out the holes in your wheels or have your lug nuts turned down on a lathe.
D/W
If it ain't broke, fix it!
PostPosted: Thu Nov 24, 2005 6:02 pm
If your looking for the 7/16x20 lugnuts for the the old style SS's Try Summit Racing. #CRR-09005-4 for RH. #CRR-09004-4 LH
PostPosted: Fri Nov 25, 2005 8:05 am
You da man.
D/W
