lug nuts
https://slantsix.org/forum/viewtopic.php?t=15137
Author:  mopar_nocar [ Thu Nov 24, 2005 5:50 am ]
Post subject:  lug nuts
i purchased a set of SBP cragars from ebay. the guy only had 11 lug nuts. (obviously) need 9 more. i can't locate them locally. the tire shops and chain stores only have lugs whose shanks are bigger. (diameter of shank, not length)
i can turn the lugs down so they will fit the wheel, but i'd like to find a set of the proper ones. anyone out there have an idea about where i can find OLD style Cragar lugs?
sb
Author:  Charrlie_S [ Thu Nov 24, 2005 6:49 am ]
Try www.cragarwheels.com
Author:  Dennis Weaver [ Thu Nov 24, 2005 8:06 am ]
If that doesn't work, try here:
http://www.prestigewheel.com/cgi-bin/co ... n&key=5203
...you may have to ream out the holes in your wheels or have your lug nuts turned down on a lathe.
D/W
Author:  Troubled64 [ Thu Nov 24, 2005 6:02 pm ]
If your looking for the 7/16x20 lugnuts for the the old style SS's Try Summit Racing. #CRR-09005-4 for RH. #CRR-09004-4 LH
Author:  Dennis Weaver [ Fri Nov 25, 2005 8:05 am ]
You da man.
D/W
