| Unfortunate Electronic Ignition Question https://slantsix.org/forum/viewtopic.php?t=15149 |
| Author: | Daddiojoe [ Fri Nov 25, 2005 1:34 pm ] |
| Post subject: | Unfortunate Electronic Ignition Question |
My electronic ignition kit from my friends on Ebay arrived without instructions. It all looks pretty simple, except for three wires. Where does the blue striped w/yellow wire go? Where does the green striped w/ red wire go? Where does the black striped w/ yellow go? Thanks very much and hope you all had a great T' giving, Joe |
| Author: | Eric W [ Fri Nov 25, 2005 4:44 pm ] |
The black w/yellow tracer goes to the negitive post of the coil, the blue w/yellow tracer goes to the run side of the ballast resister. Green w/red tracer is not used. Just cut and cover it with tape. This is assuming your using this with a single ballast resister, not the dual resister. Yes, you can use a 5 pin ECU with a single resister. |
| Author: | Daddiojoe [ Sun Nov 27, 2005 8:52 am ] |
Thanks, Eric. We'll see how that works. Joe |
