It is currently Mon Jun 15, 2026 1:49 pm
PostPosted: Wed Nov 30, 2005 9:38 pm
Okay, this started last night. The amp guage needle decided to peg to the charge side for a few seconds then the nuetral position(straight up and down). When it did this the light got brighter. Last time this happened the guage just bounced all over the place. It turned out to be my alternator. Could it be my alternator again or is it the voltage regulator? I'm running a 72 and up electronic ignition and charging system.
Thanks-Dart68
PostPosted: Wed Nov 30, 2005 9:41 pm
It's more than likely the VR... that is, unless something is grounding inside the alternator or the field wire. Most likely the VR fixes it.
D/W
If it ain't broke, fix it!
PostPosted: Wed Nov 30, 2005 9:56 pm
What'd you buy for a replacement alternator? If a parts store "remanufactured" unit, that could very easily be your problem.
PostPosted: Fri Dec 02, 2005 7:15 pm
It was the voltage regulator. Its replaced now.
Thanks guys
